Firstly, wasn't sure wether to put this here or in the floors section - hope I made the right choice
I want to pull up all the old floorboards in our upstairs rooms.
They are all old floorbards, and have split, cracked, been cut when heating was fitted etc. As such they now all squeek, bounce and are pretty uneven.
What is best to replace them with and what thickness? I also want to screw them down to stop nail creep - is this a good idea or not? Good underlay and carpet will go back on top when it has all been finished.
Also, the current floorboards are about 13-14mm thick and run "under" the interior walls and skirting. What's the best way to get round this if I use a thicker replacement (say 18mm hardwood ply)? Do I just butt-up to the skirting or do I route the edges to fit it under? If I could get away with 12mm hardwood ply? That would be great because it would pretty much be a straight swap and would slot in under the skirting!
Lastly, is this something that a non-DIY-savvy beginner can do with a bit of help from a pretty handy Dad?
Ultimately, I want to get as flat and quiet (ie no squeaking) a floor as possible.
Cheers,
Face
Cheers,
Face
