What's the best material for inset basin to sit in?
13 Jul 2005
Hampshire
Any suggestions on what the best material is for putting an inset wash basin into? I am looking at an area that is probably 1.5m x 0.5m, this will have the basin inset into it. I won't be doing the work but I don't want to specify something that causes too much pain for either me or the builder doing the work. Specifically, I guess it needs to be relatively easy to cut the hole in it and it won't end up rotting and falling to bits with a bit of moisture ingress.
What are the options?
Corian by DuPoint every time. It can be made to your drawings, so you don't have to cut it at all. Just fit your sink and tap(s). Job done.
Oh and it looks great too. I had a kitchen island made from it.
For more info click here.
standard worktop,with any exposed bits.e.g the cut out.sealed, i use pva.in the end the basin itself with a good silicone seal to hold and to seal it should do the job.works for kitchen sinks.
Thanks for the suggestions.
The Corian material looks interesting but the tech information has a warning about nail varnish products. This may be a problem as the surface is likely to get plenty of this splashed on it as the bathroom will be used by my two Daughters.
I am not sure about the tiled plywood idea as we want a seamless surface. Maybe bang down a marine ply substrate and put something seamless and hard wearing over the top - coloured toughened glass maybe!
Using a standard work-surface as used in kitchens feels like the right way to go but I have been caught be water damage on this sort of product in the past. I guess if the exposed chipboard is sealed well enough it may be up to the job.
Thanks again for the suggestions.
Steve
