Whats the best way to cut this quadrant post?
8 Jun 2022
I need to cut this radiused corner post to the needed height, and mulling over the best tool and approach to the cut. A good finish would be ideal, but the cut will end up below the worksurface, so not too critical. I have a hand saw, and a circular saw. My thoughts are to cut it slightly over sized with a hand saw, and then use an orbital sander to finish to the mark. I guess clamp it down on one of the flat sides, and cut onto the curve? Any thoughts?
Thanks Andy. Its not fitted yet, so free to move it around. I don't have a chop saw though. I have a bench to work on, just unsure how to best go about cutting it.
Mark the cut line with a Stanley knife then cut it with a handsaw. Mark all 4 edges
you might need to find something 2 or 3mm thick and a bit flexible to wrap around the curve to use as a guide for the knife.
If you can clamp the piece so you only have to concentrate on cutting all the better.
Thanks for the tips, very helpful. Don't quite follow how the plywood offcuts would work as a jig? One against each flat side and let that guide through the curve?
Ah, got it. Yes, I can see how that would help guide, but I only have two flat sides and the curve so will have to see if I can position in such a way that the circular saw can get at it. Its 100mm each side, so that may mean a cut from both sides.
I think I'll score it as Notch suggests, then clamp into two bits of plywood for guides, and see if that looks as if it'll work.
thanks guys!
All done! I used two bits of wood clamped on as a guide, scored with a blade, then cut carefully with a handsaw. Its a lovely clean cut, no breakout that I can see, and I'll need to shave less than a mm off in one place with the sander. Really pleased with that, and thanks again for the guidance.
