Hi Folks
Baxi Bermuda 50/4 Back Boiler
Gravity Hot water (with injector tee)
Pumped CH
I recently retro fitted a pump over run circuit to my heating system as the pump immediately turning off along with the boiler was causing the boiler to Kettle. As a direct consequence I was only able to have the boiler stat at the lowest heat setting (rads in region of 50deg) which meant the house was slow to warm up. Now that I have 30 seconds of continued pumping after the boiler shuts off I can now have the rads much hotter and the banging noise is now gone completely. I have chosen a rad temp of 70deg which now heats the house up nicely (position 2 on the boiser stat). The majority of the rads don't have fins on the back hence why I feel a hotter temp is required to radiate the heat out to the rooms better.
Anyway...
When the radiator temp nears the 70 degree mark I get this whistling noise coming from the boiler. Any ideas what it is?
PS turn up your speakers
https://www.youtube.com/watch?v=LeQb7rpEPRI[/url]
Pumped CH
Anyway...
