Starting grounds works on an extension in a week, which I'm planning to build under permitted development and using a building notice.
The extension will be 4m deep by 10m long, and will have a flat roof with 1 or 2 skylights.
I've done the plans myself and it all seems fairly standard and straightforward. Just trying to figure out where I'll need to get an SE involved (if at all):
- Letter A: Opening up the old external wall to create a 5.5m opening. Assumption is that I'll need an SE for this.
- Letter B: Removing existing window to create an opening (exactly as wide as existing window). Assumption is that I don't need an SE as a lintel is already in place above the window.
- Letter C: This will house a standard set of French doors. Assumption is I won't need an SE and I can use an off the shelf lintel that is 300mm wider than the opening.
- Letter D: 5.5m opening for sliding doors. Assumption is I'll need an SE to calculate and specify a steel beam.
- Bonus question: will an extension like this require wind posts, and do I need an SE to specify these? Conscious that the wall between C and D might be vulnerable.
