The radiator in my hall needs replacing. I need to find a new single 1500mm long one, either 600mm or 620mm high (hopefully a cheap one!). Unfortunately all new ones appear to be either 1400 or 1600 long.
The reason for this is because the pipes in the floor are set in concrete, with a new glued laminate floor on top, so I can't move the pipes. A 1600 won't fit in the space, and although a shorter 1400 will, I don'te really want to have bends in the pipes to the rad. Any suggestions please?
