Not sure if this is the right forum but here goes.
We have one of those vertical log edge retaining walls between us and the neighbours, put in by the builders when the estate was built in 2000. The ground on our side is around 18 inches higher than theirs. There is also a fence on our side of this log wall, put in by the neighbour before we moved in, with approx a 1" gap between the concrete posts and the back of the logs.
The neighbour has just embarked on a project to remove both the log edging (due to it rotting) and the fencing, and replacing it with a brick wall. He's told us that the fence, rather the log edging, is the official boundary. Sounds like BS to me?
We don't want the wall encroaching onto our side any more than it already is, as our path is already on the narrow side (34"). In theory a double-brick thick wall should take up the same amount of space as the fence and log edging, but we're still peeved about the work. He's using antique bricks and buff coping, totally out of character on a modern estate, and b***dy great stone pillar caps, which will be at head height on our side.
