where to get pvc tee 90 degree 40mm?
30 Jul 2006
I looked at wickes and they only sell 92.5 degree tees.
I need one like this but 90 degree angles:
Also, I had a look online and nowhere is cheap, all charging a few quid for a simple bit of plastic.
Any ideas where these can be bought from?
Are we mixing up acronyms?
You say PVC, but you show a picture of an ABS fitting.
The tees you found at 92½° are for waste pipe, which should have a fall, hence not an exact right angle.
What are you wanting a 90° tee for?
A quick online search shows companies selling them for about £1.80 plus p & p. It's not going to break the bank, stop being such a tight g*t and order one. You'll spend more than that on petrol driving around trying to find 1 :roll:
I'm building a cart to carry a kayak, nothing to do with waste pipe really :)
Like this:
http://palmettokayakfishing.blogspot.co.uk/2011/04/diy-bulletproof-kayak-cart-build.html
These things cost about 30p each equivlant if you buy them in the States. I need 7 (£12.60) and P&P is about £10-£20!!!! That's a lot of cash for some little bit of plastic made for about 5p in China.
They don;t seem to have the 90 degree ones in B&Q, Wickes, or Homebase.
Do your calculator batteries need changing?
.30p times 7 is £2.10. Where does £12.60 come from?
What size tees do you need?
