- Joined
- 1 Mar 2011
- Messages
- 60
- Reaction score
- 2
- Country
I'm at a bit of a loss what to do next.
We have a shop in the middle of a terrace of about 8 shops, built around 1900, and a leak coming from a rising main lead pipe where the outside wc used to be in the back garden. The old story - thought it was disconnected having had the wc out decades ago; it wasn't and we now have a lovely mains leak. The water supply is common. The pipe does not run into the back of the shop.
Made more interesting as a) The first four backgardens (including ours) had a workshop built on them in about 1970 so much is under there and b) the shops include a Chinese, a sandwich shop and a hairdresser so we have a window of about 2pm to 4pm for work,
Our plumber has made a temporary kludge by hammering the end of the lead pipe flat. We have about 18" of lead pipe above ground to play with.
We called out the Water Co inspector for advice, and that was to turn off the indicated stop cock in the pavement when most shops were shut and cap off the pipe.
Fair enough. It turned out not to be that stop cock. We have since tried all 4 at each corner of the block of shops, searched carefully for more, and nothing has closed it off.
Who do we ask next - is there an Severn-Trent archive department who can tell us where to look?
Or is it a case of put a tap on it to avoid a deadend, insulate and box in and leave it be?
Any comments will be gratefully received.
Ferdinand
Ferdinand
