No if you have a trickle and you have wooden floors downstairs
you'll notice nothing. It will soak straight into the ground.
Stop cock in loft? Do you mean ball valve? The meter will go round if water is being drawn through it, as (I think) the tank is still filling slightly that would account for the water usage at the meter.
If tank is being refilled at a steady but constant rate, then that water is going somewhere. If no taps are on you have a leak! You dont need a shrink, just a good plumber. That leak needs locating and repairing, otherwise risk of damage to the house.
If the leak is on a hot supply pipe then the hot water is slowly being drained off over time, and replaced with cold, hence why you find the hot water runs out quickly.
plus I've got a day's work in the bathroom if you are interested.
So where's the bloody water going!![]()
