Which Aquavac Is Best To Remove Water From Pipes?
22 Dec 2007
Bristol
Many posts on this forum mention using an aquavac to remove all traces of water from pipes before soldering etc, etc.
Can any of you plumbers out there recommend a good aquavac? As well as recommending an Aquavac, can I buy an attachment to fit between the vac nozzle and 15/22mm pipes to give a good fit? Is there one available, or have you made your own? What did you use?
Many thanks for any info.
i've been through many vacs and im useing the earlex vac at the moment.
some vacs are hopeless as you have to keep changing the filter from wet to dry
or you had to let the filter dry before useing it on dry.
as with this one it had a combined wet/dry filter. so could use on water then use on dry if you have been channeling a wall etc. without keep cleaning the filter.
as for making a tight fit over the water pipe no need as they are powerful enough.
