Hi. I'm looking for some advice on boilers best suited to my requirments.
I'm looking to install a new boiler for hot water supply only. Heating is provided by electrical Underfloor Heating system.
The hot water supply will be needed for:
- one bathroom with a bath, sink, and thermostatic mixer shower also over the bath
- one bathroom with sink only (although possibly considering a second shower)
- kitchen sink
From what I've researched myself, it seems that a good combination boiler output of 38kW or more is recommended to have a good performance from a thermostatic shower, and that the mains pressure needs to be around or over 12 litres per minute. However, this boiler recommendation was probably taking into account a home which also has gas central heating system running off the hot water (and also not taking into account a second shower).
Ideally, I prefer the idea of combination boiler giving the benefit of hot water on demand rather than the alternatives; and the recommendations mentioned previously I think were also referring to avoiding the shower performance or temperature being affected badly when someone opens up a tap in the house, which is something I would want to avoid.
Taking all my requirements into account for hot water supply only (for outlets specified) without gas central heating, assuming the mains pressure is good or an additional pump is used, the preference for hot water on demand, and wishing to avoid the shower(s) being affected badly by other outlets being used, what would be the recommended boiler specs or boiler type to use?
Thanks for any help.
- kitchen sink
