    Dismiss Notice
Which cable to power Nest thermostat?
Discussion in 'Plumbing and Central Heating' started by Munzz, 10 Oct 2021.
  1. Munzz
    Munzz
    14 Jul 2019
    94
    Thanks Received:
    Country:
    Hi All,
    Having my Nest thermostat installed next week and told the sparky I’d run a cable from where the heat link will go, to the thermostat location to save on cost/time.
    I know it powered via 12v, which cable (preferably something I can pick up from screwfix or Toolstation) will do the job?
    Cheers
  2. muggles
    muggles
    28 Oct 2005
    13,333
    Thanks Received:
    3,073
    Daventry
    Country:
  3. Sponsored Links
  4. CBW
    CBW
    26 Sep 2019
    8,977
    Thanks Received:
    2,393
    North
    Country:
    Any reason it should be used? Instructions state it can be fitted where existing thermostat is located? :confused: Also, is this what you use for OT?
  5. Munzz
    Munzz
    14 Jul 2019
    94
    Thanks Received:
    Country:
    Thanks Muggles.
    I’ve read some people say I can use alarm cable, sounds a bit like a bodge to me so would rather do a proper job.
  6. Sponsored Links
  7. muggles
    muggles
    28 Oct 2005
    13,333
    Thanks Received:
    3,073
    Daventry
    Country:
    The cable provides both power and data communication. By using screened cable, it prevents external electromagnetic signals affecting the integrity of the data stream. And yes, it is what's used for OT. Existing thermostat wires are sometimes used instead, but as the OP is intending to run a new cable anyway they may as well at least use the correct stuff
    • Thanks Thanks x 1
    • Like Like x 1
Loading...
Share This Page
