Which Ignition Coil Will be the best
6 Mar 2009
Yorkshire
HI,
I own a Megane 1.4 16v 2001. I am having problem with its coils failure, one failed early this month, got it replaced but now seems two more need replacement. i am going for all four of them. There is a lot aftermarkets. Some suggested german BERU are the best, but they cost me double than PULSE 8. also PULSE 8 is coming with two year warranty but it works in his way that you ahve to send the coils, guys check on their comp and if its faulty, they replace or they send you back. There are some SAGEMS and Original Renaul COILs are well but some say these won't last more than 6 months. SO confused what to buy. Can anyone help???
Many thanks
have you tried gsf car parts?
They usually deal with beru stuff but had vw spec coil packs in when i last went in for some for my car
Are you sealing the coil packs when you fit them?
If moisture gets in between the plug and the coil, it kills them
