I will tidy this up, put them in chocboxes and put them into the ceiling void but in a way that still makes them accessible. I have already put sleeving on the earth cables.
Will also use heat resistant flex.
Anyway I can't be certain which wire should go to the N and which should go to the L. I have since removed the two wires which are copper clad aluminium ones but modern PVC before the terminal blocks.
Is there way I can test with my multimeter which is the switched live? My understanding that on a GU10 fitting it doesn't matter too much, but on an ES fitting the side of the lamp holders (the screw bit on the bulb) could be live when when the fitting is switched off it is wired the wrong way round so I also want to double check an ES fitting we have.
As you can see nothing is labelled up.
