Hi all,
Seeking your opinions to clear up disagreement between plumber and electrician regarding which live to use for a secondary pump.
I've got a system boiler with hot water cylinder, underfloor heating and radiators so three zone valves.
The secondary pump keeps hot water flowing round a circuit so that hot water comes out of the taps around the house very quickly. Otherwise it takes ages (>2 minutes!) for the hot water to make it all the way down from the cylinder in the loft to the kitchen tap on the ground floor (it's just a 2 up 2 down - not a mansion, honest!)
Currently the live for that secondary pump comes off the switched live that connects the boiler to the zone valves.
But I've now been told it would be better to take the live from the brown wire that goes into the hot water zone valve (i.e. the one that comes from my Nest gateway to tell the hot water to zone valve to open).
I want the best compromise between having instant hot water when I need it, and minimising unnecessary heat loss from running hot water around the circuit.
Main question: Which wiring is best?
Q2: If the secondary pump is connected to the switched live of the boiler, then does that mean I'll only get instant hot water when the boiler is actually firing? I.e. in the summer when the boiler is idle most of the time, I'll be back to having to wait ages for the hot water.
Q3: If the secondary pump is connected to the control of the hot water zone valve, should it be connected to the input or the output of the cylinder stat? I'm guessing that it should be before the cylinder stat because otherwise the circuit would only flow when the cylinder is actually heating up.
Q4: If the secondary pump is connected to the input of the hot water cylinder stat, should I set my hot water programme to heat the hot water all the time I'm in the house, rather than say just an hour in the morning? If so, is that going to make my bills crazy high, or will it be negligible because the cylinder will keep most of its heat?
Thanks!
Thanks!
