Which paint brand should I use?
Buy Hamilton Perfection. Green medium pile. I use 12 and 15 inch mostly
Thanks wayners, sorry one more question. I really appreciate all your advice. In what order shall I do the painting
Paint walls - all 3 coats.
Paint skirting boards and then fix to walls
Paint doorframes and then fit doors at end after flooring goes down.
Or should I only do the mist coat first and then put on the skirting board (should I paint the skirting board before fixing it or paint it after fixing it to the wall?) and then finish with the other coats?
I paint skirting after. Some like to lay flat so paint before. Whatever, however you may need to touch up after fitting.
As for walls.. Whatever again. I like to get a coat of white on to brighten room (more light) soon as possible..
I didn't paint to the bottom - left about 10cm short as I will be fitting skirting afterwards - and skirting sticks better to plain plaster than painted plaster?
