Which paint for putty
3 Aug 2009
Somerset
Hello
Just looking for some suggested white (gloss I think) paint for one of my repaired windows that’s held in using putty?
I’ve been told linseed based but there doesn’t seem to be anything out there.
Cheers
Once the putty has 'skinned' then an Oil based primer or undercoat is OK. Once that has cured then any top coat.
Linseed oil based paints attract birds I've found.
Leave it for a good long time unpainted to dry out (i.e. several months) and then paint with any primer and top coat, the same as the wooden frames.
I've no idea about those paints. I've always used standard Dulux Weathershield gloss and undercoat.
Fine. Just paint it with whatever you're painting the surrounding woodwork with. But do wait until it's hardened.
What do the experts think? Maybe there is something you can use sooner, if you don't want to look at unpainted putty?
Water based primer will be idea but you need to wait a week or so for the putty to skin over (depending on the thickness of the putty).
If you use an oil based primer too soon, you risk it softening the thin skin and dragging the putty.
If you are planning to use waterbased gloss, that too will be OK but it will not obliterate the colour as well as a waterbased primer/undercoat.
