I have a Leisure Velstra Kitchen sink which came as a set including colour matched mixer tap about 10 years ago. Tap has copper tails. Cold is soldered to copper supply pipe and hot is straight compression fitted to supply pipe. Cold supply is mains and hot supply comes from hot water tank in upstairs airing cupboard. Tap has a dual flow spout and there are no check valves or service valves used. Hot flow is slower than cold but only to be expected.
The 'O' rings around the spout are leaking and I don't think the spout is removable to replace them even if the correct size is still available.
I was going to simply buy a replacement tap that I liked the look of and shortlisted 'SWIRL Traditional Monobloc Mixer Tap Chrome Plated' from Screwfix for £38.99 or budget busting BRISTAN Montreal Monobloc Sink Mixer from ebay for £68. Screwfix comes with flexi tails with compression fitting and Bristan comes with flexi tails with push fitting.
Given that I'm no plumber my plan is to pipe-slice the 15mm part of the existing copper tap tails and either push fit the Bristan or put service valves in for the compression Screwfix tap.
Please could someone advise me if these taps are suitable for my situation/supply and if so then any good reason why I should pay extra for the budget busting Bristan instead of the Screwfix SWIRL tap ?
Any advice on alternative suitable taps in the same price range would also be useful and any comments as to whether my plan for fitting them is good or bad.
Apologies for the length of this post but I tried to get all the relevant detail in. All advice greatfully received, thanks in advance.
