I'm hoping to change a radiator which has been in the house since it was built. The old radiator measures 571mm width x 609mm height. What size new radiator should I be looking at?
Ideally one that will heat the room up.
What type of radiator is the existing one? As they are not all the same and some have a greater heat output than others.
You may find that it is impossible to match the existing pipework up to the new metric sized radiators and some minor pipework alteration will be required.
