Whirlpool ADG 7550 Integrated Door Fallen Off
5 Oct 2010
Hampshire
If anyone has any knowledge of how to re-fix the door panel back to the face of the dishwasher, I would be very grateful.
There are 2 vertical plastic strips on the kitchen panel, which has 2 bits sticking out that goes into the door of the dishwasher, but I cannot seem to get it to stick back??
Many Thanks
( I can supply picture if helpful)
The plastic part screws to the wooden door and the lugs go into square holes in the appliance door, you should have 4 screws that need to be loosened off on the door on the inside of the appliance door opposite side to the square holes
When you fit the wooden door you put it towards the bottom of the square holes then lift it up. Then you tighten the screws on the inside part of the door which tightens the metal brackets which are part of the machine and fitted inside the door onto the plastic lugs.
