Whirlpool ADG 957 won't start after closing door
21 Jul 2007
I have pressed start and when i close door it normally starts. Have tried pushing door to ensure it clicks. Is this something simple like a door switch or sensor or do i need a new dishwasher? Have read all other whirlpool commentary would appreciate comment from sleepyhead -Thanks
Similar fault on one the other day on here.
I thought it might have been the pcb but unusual fault of the door switch being unplugged. The switches themselves aren't a common failure but it's worth starting there.
Thanks! I thought it was the door not fully shut initially. I have the cover off and there is a connector block going to the white door latch which i assume is what you mean. Plugged in and out a few times but no go. How much is a PCB if I need one? This machine is nearly 10 yrs old
Thks again
At 10 years old I'd check the wiring in the door at the bottom, can be snapped / cut where it bends to go into the base.
