Whirlpool Awm822 spins but wet clothes
29 Dec 2009
Leicestershire
Hi I have old this machine. works fine but does not spin properly. It spins but still left some water in clothes. So have to squeezethe clothes with hands totake the water out from clothes. Any one help me. Thanks. Much appreciated yours help.
Check the filter and pump for blockages also the waste hose.
If they are blocked or not working that will prevent the water being pumped out during the spin cycle.
Thanks. i do not know about the filter and pump for blockages also the waste hose. Can youlet me know how can I access filter & pump. Thanks yours kind help.
The filter is located at the front of the machine (bottom left hand side). You must remove the plastic kickplate first to get at it. Some water will run out when you remove the filter so be prepared. The waste hose is self explanatory, that's the one going to the drain. Don't you have a user manual? It's explained there, you can find one here http://www.whirlpool.eu/app.cnt/whr/en_GB/pageid/pgwpsrvifuhome001
Good luck :D
Good luck :D
I really apprecited yours kind help. Happy & Prosperous New Year to all.
