Whirlpool Dishwasher Fault
22 Mar 2013
Worcestershire
Hi
We have a Whirlpool ADG Dishwasher that is 11 Yers Old, it has not been abused with contaminated plates, but just general use about 1 a week. Last time it was coming to the end of the 60deg cycle it stopped just short of the 20 minute dwell before completing as normal. The unit then had steady beep and the light flashed by the start button. Used it again yesterday for the first time since the fault and had the same symptoms right at the start within 1 minute or so and the unit pumped out and started bleeping & flashing again . Turnd off unit and tried again. It appeared to be OK, but then had same fault towards the end of the cycle again. The filter is clean and we added salt & rinse aid just in case. The outside conditions were around zero if that makes a difference. Some people are mentioning NTC but not sure what that is? The unit is heating & cleaning well once the fault is cleared and checked drain via hose for any blockage and it does pump to bucket without issue's. Any help would be appreciated
Regards
John
