- Joined
- 10 Sep 2006
- Messages
- 16
- Reaction score
- 0
- Country
A while ago we noticed that our washing machine didn't seem to be rinsing the clothes that well - there are often streaks of powder on the clothes.
Today, after the machine had completed it's wash cycle and last rinse, I noticed that it still had a lot of bubbles in the window.
I ran the rinse cycle again (programme B) and noticed that it didn't fill with much water - you couldn't see any in the window.
I ran it on the slow rinse cycle (programme C on the delicates wash) and this time the machine took in plenty of water - about a third of the way up the window.
When this had finished, I ran B again. This time it filled with plenty of water, about a third up the window again.
Is there a sensor which the machine uses to tell how much water it has in it? If so, I suppose it could be causing this problem. I was also wondering if it meters the water into machine. In which case, I suppose a partially blocked pipe would cause it to under-fill.
If this is an intermittant fault, is it likely to be a circuit board?
Any ideas?
Any ideas?
