Whirlpool washing mahine fault codes
18 Jul 2004
Does anybody have a list of fault codes for whirlpool washer. I have an awm8163 with fault f11 showing. This came about after a blockage in the drain line. I managed to clear the blockage but this fault now shows. The manual suggests an electrical component failure but this seems unlikely as the pump failure code came first
you say pump fault code came first then this other code, it looks like you are ony giving us half the information
I would suggest you read this then
ask whirlpool 0870 600 8989
Yes.
The pump Fail code PF showed initially. This was idemntified as a piece of fabric blocking the pipe between drum and pump. Once this was cleared, the machine worked for a cycle. On restarting it, the F11 code came up. At present, if you press start on any cycle, the pump runs for about 5 srcods before beeping and diosplaying this code.
I have written to Whirlpool, but nt yet had a reply. I will as you suggest, phone them. Thanks for the number
Ta
Darren
