WHIRPOOL D/W MOD DWF 416
15 Jan 2007
Yorkshire
:cry: 3YR OLD DISH WASHER STOPPED WORKING IT WILL DRAIN BUT NOT, FILL, WHEN TRY TO RUN IT BEEPS AND BEEPS GREEN LIGHT FLASHES IN 2 FLASH SEQUENCE, THIS APPLIES TO ANY WASH IT BEEPS AS SOON AS YOU SHUT THE DOOR YOU CAN HEAR THE DRAIN PUMP WORKING THEN IT STOPS BUT KEEPS BEEPING WHEN YOU OPEN THE DOOR THE GREEN LIGHT FLASHING. WOULD BE GRATEFUL FOR ANY IDEAS AS TO WHAT IT MIGHT BE. THANKS CHRIS
2 flashes indicates a leak into the base.
Drag it out, tip it back about 45 degrees, with loads of towels around it, and drain off the water.
Press and hold the start button to reset and try it on a program.
If the problem comes again during the testing then it's got a leak.
Another cause of flooded base is overfoaming. Using 3,4 or 5 in 1 tablets as well as rinse aid.
:D Thanks for help it did the trick its now working fine
