Hi all, I am in the middle of constructing a cabinet to house an electronic musical instrument, but I am wanting it to be a very high gloss white, has anyone got any tips please.
Buy a good quality industrial random orbit sander, a full set of 3M Trizact abrasives, a 3-stage (or better) industrial HVLP spray outfit, a body polisher and a good dust mask (coz you're going to need it) and learn how to spray (and how to sand) ........ Dude, it's really hard work to achieve a high gloss finish as you'll need to have a near perfect surface before starting to paint, but a piano gloss is achievable with time and care (and 7 or more coats of finish above your primer coats). What is your substrate going to be (i.e. what "wood" are you using)?organmonster said:Hi all, I am in the middle of constructing a cabinet to house an electronic musical instrument, but I am wanting it to be a very high gloss white, has anyone got any tips please.
To get a high gloss finish (i.e. a "piano" finish) you need to go well above 400 grit, which is a good quality gloss level, but NOT what is expected when we finish to high or mirror gloss. To get a true high gloss the grit has to finish somewhere between 1000 and 1500 (or higher) which puts us into special finishing materials like Trizact and requires the use of a body buffer and micro-abrasives to get the final glazed look. Spraying radically reduces the amount of sanding out between coats and we use random orbit sanders for a better quality surface, making sure that we carefully clean off both the surface and the sander each time a grit is changed. It is necessary to work up the grits for the best finish, so no goig 100 -> 220 -> 400 grit as you'll spend forever removing the previous grits marks.hermes said:They use 6 or 7 topcoats and reduce the grit size for sanding between each coat-I would guess that they finish up with about 400 grit sanding sheets. It was hard to believe that it wasn't a sprayed finish yet they achieve it time after time. MDF is probably the best material for your cabinet as it has such a smooth surface, but you must sand the edges well or they will absorb too much paint and look rough.
Scrit said:To get a high gloss finish (i.e. a "piano" finish) you need to go well above 400 grit, which is a good quality gloss level, but NOT what is expected when we finish to high or mirror gloss. To get a true high gloss the grit has to finish somewhere between 1000 and 1500 (or higher) which puts us into special finishing materials like Trizact and requires the use of a body buffer and micro-abrasives to get the final glazed look. Spraying radically reduces the amount of sanding out between coats and we use random orbit sanders for a better quality surface, making sure that we carefully clean off both the surface and the sander each time a grit is changed. It is necessary to work up the grits for the best finish, so no goig 100 -> 220 -> 400 grit as you'll spend forever removing the previous grits marks.
I'd agree that MDF is a good substrate, however MR-MDF is probably better as it has a denser structure. But sanding the edges alone will never produce a quality finish. It is necessary to seal and sand the edges 3 to 4 times with an MDF sealant or even a car body filler and the basis of a high gloss finish will always be a good quality high-solids undercoat on top of the sealed MDF, again 2 to 3 coats sanded out between coats to 320/400 grit with the last coat sanded to 600/800. As soon as the colour coats start to go on you need a substantially smaller grit (i.e. higher grit number) and I'd sand-out between coats by denibbing (Scotch grey cloth) then sanding at 600 to 1000 grit (por higher). Trizact is difficult and expensive stuff to get hold of, so an alternative is to wet sand (water + washing-up liquid) with silicon carbide paper above 400 grit, and use aluminium oxide (alox) for the lower grits. Just go easy on the water and use a spritz bottle to apply a little moisture - all you are doing is lubricating the paper, not flooding it, so wipe off overflows all the time.
The deepest glosses are obtained by layering two or more clear top coats over a matt colour coat. This is a technique sort of borrowed from the car trade and produces a really deep glossy appearance that is hard to match with conventional solid paint finishes. It also allows you to tint the colour coat and get those pearl;escent effects so beloved of trick car owners.
markie said:White lighting, disgusting drink, would rather have woodpecker, taste sweeter,
