Whole house pump :- How does this layout look?
21 Sep 2007
Right kinda carrying on from o another thread (http://www.diynot.com/forums/viewtopic.php?t=138425&highlight=) decided to attempt to install a whole house pump myself as Im currently unable to find a pumper who is willing to do it without trying to sell me a megaflow/don’t think can be done.
I had a plumber I found around off the iphe website and he is quoting around £2100 to have a unvented cylinder put in.
Although the idea of no noise at all is appealing im quite confident I will be able to quite the pump down using various methods found on this forum. Also know pumps don’t last for ever but if I have to change the pump in say 5 years time it will still be only £200 odd.
Anyway back to the main topic, here is my super armature paint diagram of what im thinking of doing with the pipe work
I welcome any comments………..pump will be a Salamander RHP 75
I can honestly say I wouldn't do it like that and expect a good job
Use an Essex flange.
Whats the hight of the storage tank above the pump.
What volume is the stored water
Doesn't look good
lol good start :)
Cold storage is a 100 gallon tank. The cold tank is about a meter + half above where the pump will be (cold tank on a raised platform)
Only reason i looked at a surrey as it was a simple swap around, have looked at the techflange as well
Essex or Techflange is good.
You want to avoid the wc being on the pump where possible.
Simple is good but not the best way to install it.
I would recommend that you make provision for the pump breaking down and connect directly to the DHW before the pump using a gate valve to isolate this branch in pipework.
Then if the pump does knacker at least you have a way of getting some hot water even if it is at a reduced flow rate.
Surrey are a bit of a pain to install, but i would use a Warix.
Restricts the flow too much, especially on an whole house pump.
toilets are all mains feed so thats ok, i will put a non return value on the washing machine feed.
If pump does pack up one day (they do last a while) im 99% sure that you will still get hot water just not at pressure
