Hi folks,
I have been in this house for a year and one radiator in one downsairs room has always performed poorly. The hot/flow side of the radiator inbound pipe is really hot but the rad itself never gets more than luke warm.
I have obviously checked for air locks and I have tried adjusting the lockshields on the other rads to see if I can force a flow through the rad without much success. Sometimes it has got warmer but on the whole it is very poor.
The previous boiler was replaced earlier in the year for a Worcester combi and made little difference to this particular problem. Since then, we have recently extended the house and added two more rads attached to the flow and return which feed the subject radiator.
At the same time, I have replaced all the other downstairs rads (5) in the downstairs flow/return loop including thermostatic valves and lockshields. I now have the same symptoms on the two new rads leading on from the subject radiator.
The inbound/flow/hot side of each radiator is hot, far too hot to hold. The outbound pipe from each radiator is barely warm. My feeling is that there has to be a pipe blockage on the return side between the original dodgy radiator and the next working downstairs radiator return.
Although I would expect the return loop to be cooler than the flowside, I'm assuming it will not be as dramatic as I have, i.e. the difference between being too hot to touch on the flow and barely warm on the return.
Would you agree there has to be an internal pipe blockage between the working and non working rads on the return loop?
Appreciate your advice.
David
David
