Nothing, it is what all switches do when switching in air, but it should be quite brief. If it is not brief, then it suggests the switch might be worn.
Dare I suggest just blinking, when you throw the switch, so you don't see the spark?
Any switch which makes or break when carrying current, will spark, there is no sensible way to avoid the arc as the air and metal in the gap is is ionised.
I AM REPLACING THE FAILING MK STUFF WITH CHEAPIES and so far I've found them to be more reliable. We refitted the kitchen about 15 years ago and I decided to use decent stuff, MK DSSO's with neon, purchased 10 for the price break for the 7 required. all 3 spares got used up as replacements and now there is only one left in use.
So far I have not had to replace a Wickes cheapie...
Although my question may have seemed flippant it was actually serious. I thought you may have written them the wrong way round but after your explanation I can fully understand. Sorry if I caused you any offence, it was not meant.
