Why is tiling on chipboard a no no
  • Thread starter Thread starter SL
  • Start date Start date
SL
17 Jun 2007
Suffolk
Why is chipboard the worst thing to tile on. (except carpet)
I was advised my by local builkder merchant, that tiling onto chipborad in a bathroom was ok, so I installed 22mm P5, which I can not take up. The max thickness I can have including tiles, adhesive, ply / backerboard etc is 20mm.
Bathroom 2m * 1.7m, joists spacing about 12" apart.
What should I do? 6mm backerboard / ply, screwed to floor ?
as long as the floor is solid you can use a 2 part adhesive. bal fastflex or dunlop tile on wood rapid will do the job. dont use a pre mixed one from diy chains as they take weeks to go off
Bal may say that their Fastflex would be suitable for tiling on chipboard floors (assuming that you have checked with the manufacturer for suitability - most chipboard just turns to mush when wet) and it might just work. What you failed to mention is that you'd need to take out a second mortgage to buy Fastflex. A cheaper and better option is to overboard with ply and just use one of Bal's regular flexible adhesives (either single part flex or rapidset flex).
I have put 2" * 2" bit of chipboard I used, under water for 13 hours and I can not pull it apart. i'll see what happens when it dries out.
if you'll pay the postage, I'll send you a bit that was in the bathroom and got dripped on occasionally.
Now chipboard is dry, it's 1mm thicker.
decided to over board with 6mm ply. Is it best to glue & screw ? If the tiles I use are say 10mm, will 4mm of adhesive be ok.
Thanks.
Use 9mm ply as an absolute minimum (12mm is better) - 6mm is way too flymsy. The ply is used to add rigidity as well as to give a stable tiling surface. Read the tiling sticky for information on fixing ply.
Use a 10mm radius notched trowel and I recommend using Bal rapidset flexible or Bal single part flexible.
You can go on top of chipboard but like its been said in the posts before mine Bal fast flex 2 part is the only way. But there is 2 other adhesives
1 - Dunlop 2 part rapid set flex (tile on wood they have just had a change around and changed the names of some things)
2 - Profix tile on wood
Take a look at the back of the bucket and see where this product is made.
It looks like the same product line as BAL and Dunlop so its going to be good stuff and at over half the price of Fast flex.
I found this at trades-direct its a bit stiffer than the fast flex but you can save your self a bob or 2.
