Width of footings
23 Aug 2004
I'm having a (nearly) full width conservatory built in a few weeks on the back of the house and then an extension on the side of the house next year. The back wall of the extension will be in line with the back wall of the house.
Because of this work I have to have the gas meter moved so that the service pipe is not inside the conservatory.
I want to have the new meter installed in a semi concealed meter box (that sits in the ground) so that it will overlap from the existing back house wall and to the new extesion wall (it cant sit entirely on the house wall because of the size of the conservatory and the location of the soil stack)
My concern is that I will get it installed somewhere that will interfere with the building work when I get the extension built. If the back wall of the extension will run in line with the current house back wall how much wider than the width of the proposed extension back wall will the footings be when they are dug by th ebuilders. A better way of asking that would be how far away from the proposed extension wall should I get the gas box installed. I don't really want to move it again when I get the extension done.
Thanks,
Matt.
Have you given consideration to your DPC/DPM. If you are proposing to sink the meter into the ground, within the house, you may very well breach this.
Since gas is heavier than air, I would also be concerned about putting the meter into a sunken pit. Any minor leak could cause a dangerous accumulation. I wouldn't be surprised if there is some regulation to prohibit this, in fact, I would be surprised if it IS allowed. Perhaps one of the Corgi guys will know better.
