I have just redone my kitchen fairly cheaply. I wanted a handleless style one. I replaced my cabinet and draw-fronts (but left the actual cabinets in). I replaced the plinths under the cabinets, and replaced the worktops. However, my kitchen is very straight forward and fairly small. If you have anything like bendy corner units, you may need to modify the kitchen design as these can be hard to find and expensive.
I purchased 7 715mm x 595mm handleless, gloss white replacement doors (~£500), 1 fridge-freezer gloss white door (~£100), one 490mm double oven door (£60), 9m worth of replacement kick plinth (~£170), 3 new 595mm drawer fronts, and 9m of black gloss laminate ‘taurus worktop’ from
wickes plus edgings (£275). I also used a modified deep cabinet door, turned 90 degrees as a new extractor fan cover (£80). With appropriate new fixtures and fittings (which I had to buy separately from
Wickes and B&Q, as well as a new power drill (£25), and a few other cheap non-essentials,the kitchen came to just over £1260 altogether. It is however, a very nice quality finish and looks far more expensive.
Note, this does not include retiling (wall and floor), which I also did myself. For the wall tiles, I used some amazingly good value (85% off) large (300x300mm) white tiles (£16 for 2 big boxes) I found in the clearance section at
Wickes, with a speckled black 300x300 one added in every so often (~£5 for 8 tiles, (also massively reduced). For the floor, I used 300mm by 600mm ‘riga’ beige porcelain floor tiles from
wickes, which were expensive at £3.50 per tile (~140 tiles used).
My kitchen is fairly small. Due to my kitchen’s design, I was also lucky that I did not need any ‘tall’ or ‘base’ end panels. It took me four days (about 25 to 30 hours) to assemble.
The total New kitchen including the new cabinet and draw fronts, edgings, kick-plinths, worktops, wall, and floor tiles came to just under £1800
I used this ebay seller as my main source for the cabinet and drawer fronts:
http://www.ebay.co.uk/itm/HIGH-GLOS..._KitchenFurniture_EH&var=&hash=item19c9e039ae
