WILL MY HONEYWELL 4073 VALVE BE OK TO BE REPLACED BY SEIMENS
11 Aug 2008
Durham
HI WILL A SEIMENS 3 PORT 22 MM VALVE DA-V322 BE OK TO REPLACE MY HONEYWELL V4073 PLEASE IF IT IS COOL IF NOT BOO HOO WHY NOT THANKS ANSWERS WOULD REALLY HELP
SIemens valves are cheap and nasty replace with honeywell it will save you in the long run
the v322 is a diverter valve not a mid position.
the v4073 is a mid position valve.
if you fit a v322 you only get hw or heating not both it works on priority
where as the v4073 gives hw/heating together.
in my opinion fit a horstman.
its a direct replacement, cheaper & comes with better guarantee.
Don't use a Horstmann. When you put this valve in manual position is closes the end switch and always fires the boiler. Same on a Sauter Valve. Stick with the Honeywell.
Seco was never going to fit one.
The OP posted just once in the last two years.
Not likely to be avidly following this thread now.
Tony
