Window Condensation
21 Aug 2013
Sheffield
Morning,
One of my pet hates is window condensation on a morning. Last year we had our old uPVC windows replaced with A rated windows which I hoped would help solve the problem. This hasn't been the case, speaking with the window fitter they've suggested it now might be even slightly worse as the windows allow less drafts through than the previous units.
Apart from leaving windows open which kind of defeats the object of A rated windows can anyone offer any sensible suggestions of how to reduce the condensation on the windows during winter months?
Many thanks for any help.
You either have trickle vents fitted or leave the windows on the night latch overnight. You cannot achieve your Utopian Vision of a completely sealed up house and no ventilation unless you stop breathing.
As the windows came from a small fitter it was one style of window or nothing, the windows fitted don't have the trickle vents in.
Think i might just pull the house down and start again, get myself a ground source heat put and heat recovery system which might help with the ventilation. However the neighbours might not be happy :)
As a window fitter personally I hate trickle vents. Noisy, drafty little dirt traps.
You need to reduce the moisture in your house. I have compiled a few links on condensation on an old forum here:
http://www.double-glazing-forum.com/topics.aspx?ID=34
There are a few extra links there to read too.
Biggest no no is drying clothes on radiators and indoor plants.
A dehumidifier is a good idea if you wont/cant change the causes of the moisture in the air.
Did you have trickle vents installed in the new windows?
I thought it was compulsory now to have trickle vents fitted, on all new windows.
Edit found this
Trickle vents have never been required by Approved Document F of the Building Regulations. They are just one way of providing the basic background ventilation that is required, but permanent vents in walls are a better option, with the necessary mechanical extraction in bathrooms and kitchens.
The current Building Regulation defines the required amount of “whole house” ventilation, while in the Nineties it referred to individual rooms. But the net amount is basically the same — about 8000 sq mm for a living room, achievable with a 75mm x 225mm plastic wall vent with a screened cowl externally and a hit-and-miss sliding cover internally.
& this
http://www.partf.co.uk/news/adf_update27.htm
