Window Locking Mechanism Size.
28 Aug 2014
Leeds
Hi guys,
One side of my locking mechanism broke on my window.
I popped off the beading and drilled through so I could see the slider and dragged it back with an allen key which allowed me to open the window.
I looked online for a replacement mechanism but some of the standard sizes seem to be 400mm and 600mm and when I measured the length of my window at the bottom it was 480mm.
So my question is, am I going t have to get one specially made and where from or am I just looking in the wrong place??
Thank you for any help :)
have you measured the length of the espagnolette mechanism?
assuming its a single espagnolette with just mushroom keeps then it will be the next size shorter than the window
what is more more important is whether the locking part is offset or centred + you need to get an esp lock with same mushroom length
I haven't taken it out yet as the winds been a bit strong and it's an upstairs window. I did notice that as well as those mushroom sliders there was also flat metal bits that slid out at the ends so assumed the mechanism is the full length at 480mm.
I'm hoping for better weather for the weekend so I can get up and take it off.
Update:
Turns out it was the gearbox that was broken so just had to get a new one and fit the ends on to it.
All fixed now. :)
