windows opened to the inside or outside? which are better.
12 Jul 2010
I was recently in England and I noticed that a large part of windows opens to the outside.
In Poland the opposite is true.
How do you think that way is better?
if you are in a country that habitually uses external shutters, you can't use a window that goes outwards. In the UK shutters are seldom used on domestic buildings. Some older houses have internal wooden shutters that fold back into the wall and are concealed, these are mostly designed to work with sliding sash windows but can also be used with outward-opening casements.
however a window that goes outwards does not take up space or cause an obstruction in the room. Inwards opening windows can also be incompatible with some curtains. I have been in places with inward-opening tilt-and-hinge plastic windows and found them very inconvenient when hinged.
Building practice is very traditional and slow-moving so I am sure builders in each country like what they are used to, and think it is best.
You have a lot of arguments in. But for us in Poland when the window is opened to the inside does not cause any problems in use. In my opinion, the window opened to the outside may cause more problems when using. I works with Windows and doors manufacturer and I wonder whether the England changing trend on the window opened to the inside
Who gives a toss frankly, as JohnD mentioned, windows in the UK have been opening outwards for hundreds of years and are unlikely to change. Where would Mrs Smith stick all her chintzy rubbish if the opened inwards anyway? But really, do you have a point at all?
