Windows sill and a camera mount - what glue?
15 Jul 2022
Hi All,
I hope you are doing well.
I have a quick question. What would be the best to glue two PCV surfaces together.
I understand I have to sand it and clean it before application.
I want to glue a relatively thin and flat piece of PVC for a camera mount onto the window sill.
I don't want to drill holes.
Thank you
Best regards
Either glazing tape if you happen to want to remove it or super glue with activator for a more permanent solution
right so you advise to use some strips of glazing tape or get a single wide piece and attach it.
From what I measured the PVC piece is going to be 100x200mm so the attach surface is going to be 100mm X 100mm.
Superglue large washer to Sill and add magnet strip to camera base , make it easier to remove /adjust.
This is exactly what I did and the camera was not blown away during the 50mph winds we had earlier this year. Thanks again.
