wire
idb
28 Mar 2005
Hi just a quick question on wire sizing. :confused: wire size like 2.5 i understand is measured on the cross section of the wire . but 16mm and 25mm what does this measurment relate to?
same.
all electrical cable is measure by its cross sectional area
o.k. but a piece of 25mm is,nt 25mm across so how can this be? :confused:
as i said, cross sectional area, that is to say the area of its cross section, or if you were to "cut off a slice" and measured its surface area the reulting figure would be that of the cable size
When you saw the warning about replying to an old thread, what reason did you think you had for ignoring it?
