Wired new Fan and Isolating switch but fan running
Shed, I'm not saying the the diagram is wrong. I very much doubt it would be as its on here, I was just after some help trying to understand it.
If you put Y rated tyres on my car I'm not sure I'd want it to go as slow as 180 MPH.
Don't be worried about my job, I've done it for the last 16 years and been to some pretty honking places in some horrendous conditions so I'm fully capable of that.
What I ment by a 10A wire is its normal 2.5mm but its coming straight from the consumer unit and at the consumer unit it's a 10A fuse.
You're an electrician, and you can't understand this?:
You're an electrician, and when you look at that diagram your interpretation is that because the fan isolation switch is rated at 10A, and the circuit is a 5A one, if you install a fan which draws between 5A and 10A "things would blow even though there isn't a fault"?
:roll:
¿Que?
What do the instructions for the fan say?
Sorry shed, I can't see it. Lets not dwell too much and we are clogging up someone's thread with chit chat. I understand the diagram and that the fan would work, im not saying it wouldnt. I just don't get how it is properly done. If you like to explain it then through me a PM. I must be missing something.
Can't see the point.
No matter how hard I try I cannot begin to understand what on earth you could possibly see in that diagram which is not properly done.
