Can anyone help. Have connected an in-line bathroom timer extractor fan via 3 pole isolator. Problem is that the fan runs when the light switch is operated but only when the L1 and L2 had been reversed at the isolator. If I connect L1 and L2 as instructed, the fan will only operate by the isolator and not by the light switch. When the light switch is pressed off the fan stops,
I cannot make the timer function work.
Isolator switch operates, when switched off and light switch pressed on fan does not work. What have I done wrong?
Help please!!!!!!!!!!!!!!!!!!!!
