wiring a draytonRTS8 combistat
10 Dec 2005
Suffolk
hi all ive just bought a RTS8 combi stat to wire up to my worcester 28si combi boiler the terminals are as follows : neutral ,live and switched live on boiler , and stat has terminal marked N neutral terminal 2 and 3 and live . it says i need a 3 wire connection using neutral, live, and terminal 3 which is n load call for heat . neutral goes to neutral on worcester terminal, and the live on stat goes to live on boiler , and the terminal marked n load terminal 3 on stat goes to switched live on boiler does that sound wright . i was bit concerned why pin 3 on stat has n on it when it has to go on swiched live on boiler
Have a look at the post by chrispriddyuk on same subject. There is a link to the wiring diagram.
The n load had me fooled for a second or two. From terminal 3 it is a switched live to the 'load' and obviously after the load it is neutral.
:rolleyes:
many thanks mandate i begin to wonder if anyone would help me loads lookers but no one replying for some strange reason any way thanks i will look at his post
hi would you run 3 core flat pvc to boiler from stat or should i use 3 core flat into fcu then take 0.75 flex to boiler , can some one tell me the correct way please . i like to do things properly
