Can any one help. I am trying to wire a pull switch but instructions only show earth and live. Where does the neutral go? BTW using Twin and earth Black Red and Earth.
If you are replacing an existing pull switch that has only one cable with red black and bare copper with green yellow sleeve then the red wire is live and the black wire is switched live and NOT neutral. The BLACK should have a red sleeve ( tape) on it.
