wiring a relay?
25 Jun 2008
Manchester
could someone give me a little advice on the terminals i need to use on a 5A mini dpdt 230v relay.
the cables to be used are
1- line
2-neutral
3-s/w 230v
4- outgoing cable to boiler to switch ON
5- outgoing cable to boiler to switch OFF
the terminals in the relay are as follows
4 1
8 5
12 9
14 13
http://www.maplin.co.uk/Module.aspx?ModuleNo=37515
any help appreciated, cant seem to get any info elswhere to help me out
None of the above mate I doubt, that relay you have linked to has only a 12v coil
what are you trying to achieve?
make/model of boiler would be useful too.
Matt
This will put Live to boiler ON when the coil is energised by switched live. and put Live to boiler OFF when the coil is not energised.
Make sure you get the relay with the 230 volt coil and the correct matching base.
thanks for the diagram, just what i needed, yeah i have got the 230v relay, the link wasnt great. im wiring up a quinta pro boiler via a honeywell v4073 using a y plan. But using this boiler have been told will need a relay between the s/w of the valve and the boiler position on/off terminal to fire it up.
