Hi everyone,
New guy here; I am competent with basic electrical wiring / conscious of safety. I have completed relatively simple tasks such as wiring extractions fans, installing storage heaters and convectors, and have helped others with more complicated stuff like installing new circuits. I want to build my experience by doing some minor wiring jobs as follows:
please can someone more experienced with leccy confirm the below is correct/ok:
I have two minor wiring projects to do:
- lights in the loft (2 60W bulbs)
- power supply to built-in closet I am converting to hold a PC etc an "office"
For convenience/speed I wish to use radial circuits.
Both cable runs are short (~5m max) and tacked to surfaces
I have spare MCBs in my brand new consumer unit as follows:
-for the loft lights, I will use a 6 amp MCB
- for the power supply, I will use a 32 amp MCB, in an RCD protected bank
There is likely better sized MCBs available, but these are what I have (trying to keep cost down).
Cabling is as follows:
- for loft lights, 1.5 mm2 twin and earth, linked to a switch and then a junction box feeding two batten bulb holders
- for power supply 4mm2 twin and earth, linked to a double socket on other end (I will put an extension cable in for more sockets).
I would appreciate any advice as to whether or not this is acceptable - please do advise on any errors, especially if the cable sizes are OK or not in radial circuits with the stated MCBs.
I have some questions re the connections I will use:
- does the light switch have to be fused (size?) / rated?
- what rating of junction box? (anything above MCB rating?)
- is there a rating for the double socket in the power supply?
Also, I believe it is OK to use 4mm2 cable with a 32 A MCB, but as the cable is rated for 32 A itself, isnt this cutting it a bit fine? I understood a margin between the cable/MCB rating was desirable?
Thank you very much for any advice - sorry for the big post!
