I need to install 1 electric radiator into a room. I can buy it hardwired or with plug socket
Now the plug socket is not near by where the rad is getting installed, but there is a plug socket directly behind the wall on otherside in the room behind.
for aesthics of wiring I want to drill the plug wire through the wall and then plug it into the socket directly on the wall behind.
So should I buy the radiator with hardwired option, push the cable through the wall then add a plug to the wire and plug it into socket?
Or I can buy radiator with plug, cut the plug and route the wire and add the plug back onto wire?
I just don't know which version of rad I should buy or of it makes a difference cos I need to cut the cable regardless and add a plug socket to the rad.
