Couple of quick questions please.
We're having a new boiler installed and the plumber has asked for a shuttered, unswitched socket outlet fused at 3A. I've checked the manufacturer's installation requirements and this is right.
Having taken the old electric shower out, we now have a spare way on the fuse board which I'd like to use to keep the boiler separate. Appreciate that this is Part P territory and the intention is that I will run the cable and fix the socket but a sparky will connect to the board.
1. I understand that buried cable doesn't need to be protected according to Part P. Is this correct? I'm providing trunking wherever I can but there will be some areas passing through walls, joists etc. where this is possible but more difficult.
2. As the socket is fused at 3A does this need to be run in 2.5mm or 4mm as a normal socket circuit or will 1.5mm suffice? Nothing else will be on this fuse.
Thanks again
Thanks again
