I'm doing the wiring in a new build to be Part P tested afterwards.
We're having a Baxi combo boiler installed. The wiring says it needs to be
"3amp 230v 50Hz supply control using cable of 3 core .75mm 3183Y multiple flexible type"
Plan is to run a separate supply off the consumer unit to a switched socket with a 3amp fuse, standard circuit cable to the socket then cable to the boiler.
Does that sound right, or am I missing something?
