I have a outside light which the previous owner wired up into a existing light fitting so it came on with the hall light. I wish to put the light on a sepearte switch. Inside the light switch the live is switched.
How do I go about wiring this in so it can be on a independent switch? How does the wiring go? There is a junction box in the loft where the power comes from the fuse board. I can use a permanent live from here. But do I go from there to the switch then to the light?
Thanks in advance!
Thanks in advance!
